pipe thread
jtrowbridge
pipe thread
All,
Need a cosmetic thread for a pipe thread......male thread.
Any tips on how to create it?
I tried to do a revolved cut with a taper then put a cosmetic on that....Creo crashes
Jon
mlocascio
(To:jtrowbridge)
Jon,
Yes, I do have an excellent idea for what you are trying to do. What I do is
create a datum curve in the model that represents the ID of the thread.
Model the pipe thread's OD as a solid feature. Don't forget to change the
properties for the curves to a hidden line. I also like to change the color
to a shade of gray. Make sure that your curves are in the correct view
orientation. It is more work than one should have to do. Hopefully someone
else will come up with a better idea.
Michael P. Locascio
_____
This email and any files transmitted with it are confidential and intended
solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager.
This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not
disseminate, distribute or copy this e-mail. Please notify the sender
immediately by e-mail if you have received this e-mail by mistake and delete
this e-mail from your system. If you are not the intended recipient you are
notified that disclosing, copying, distributing or taking any action in
reliance on the contents of this information is strictly prohibited.
