Using Creo 4.0. I am trying to figure out how to create a table that shows up on my drawing that pulls the pipe length information and inputs it directly. I've been trying to figure out which parameter it is but have not figured it out. Is there anyone out there that can help me with this?
How are you creating your pipes?
If you are using Advanced Framework Extension, then the parameters are in there as BUW_xxxx, I think length is one of them.
If you are just creating pipes in a family table or standalone, you can rename the driving parameter to Length and use that in a table.
I did create a table that shows lengths for an AFX developed structure of steel channels.
This assembly used tubing, not pipes, but you get the idea.
