CODE:
var assembly
function udfInPart()
session = pfcGetProESession ();
assembly = session.CurrentModel;
var part = session.GetModel ("60606060-000.PRT", pfcCreate("pfcModelType").MDL_PART);
var ids = pfcCreate ("intseq");
ids.Append( 0 );
var path = pfcCreate ("MpfcAssembly").CreateComponentPath ( assembly , ids );
var items = assembly.GetItemByName( pfcCreate("pfcModelItemType").ITEM_COORD_SYS, 'ACS_TOOL' );
var sysRef = pfcCreate("MpfcSelect").CreateModelItemSelection (items, null);
var Ref1 = pfcCreate("pfcUDFReference").Create("ACS_TOOL", sysRef);
Ref1.IsExternal = true;
var Refs = pfcCreate("pfcUDFReferences");
Refs.Append (Ref1);
var UDFInsts = pfcCreate("pfcUDFCustomCreateInstructions").Create("test_udf");
UDFInsts.References = Refs;
var NewUDF = crvSet.CreateUDFGroup(UDFInsts);
Sorry, first post was too fast ![]()
Hello PTC communtiy,
i need help according an issue using weblink/jlink for placing an udf in an part (with references from the assembly), which is an member of an assembly (root).
Everything works fine so far, i can place different udf's in the part using weblink.
But as soon as i want to edit the feature (after placing) i get an prompt that Pro/E is missing the external references.
How can i solve this issue? I have tried different things, but i still get the same failure all the time.
When i place the udf's direct in the assembly, everythings just fine and there is no "external references missing" prompt.
I have attatched a picture for you, to expalin the modell structure.
The weblink code is shown above ![]()
Thank you very much for any advices in advance.
Berst regards.
Markus
if your company has active Global Support at PTC, then I suggest you to open Case at PTC Support.
MH
