preferred_save_as_type
dbreen
Hi everybody,
maybe a simple question, but I can't figure it out. I've included the following settings in my config.pro:
preferred_save_as_type PDF
preferred_save_as_type STEP
preferred_save_as_type DXF
When i open Creo these settings appear in the loaded configuration settings under File > Options > Configuration Settings. However when I create a new part and select File > Save As > Save a Copy the type list is still in default configuration. Am i doing something wrong or...?
I am running Creo Parametric 3.0 M030
Thanks in advance,
Dave
TomU
(To:dbreen)
It looks like PTC broke it between Wildfire 5 and Creo 1 and is finally fixing it in Creo 4.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS61360
6 REPLIES 6
TomU
(To:dbreen)
dbreen
(To:TomU)
Then it makes sense that i do not get it working!
Thanks for your reply!
Dave
I didn't find any other threads except for this one.  I'm using Creo 4.0 M050 and trying to figure out this preferred_save_as_type option.
What do I put as the options?  I've tried STL, .STL, *.STL, Stereolithography (*.stl).  None seem to change the default list of types in the drop-down menu or the default.  If I wanted to order it like STL then PRT, what should I enter?  And does it work for Creo 4.0 M050 in the first place?
TomU
(To:ptc-6101083)
There are some issues with Creo 4.0 F000 to M050.  These have been resolved in M060.
https://www.ptc.com/en/support/article?n=CS275800
The behavior of this option is fully documented here:
https://www.ptc.com/en/support/article?n=CS225292
ptc-6101083
2-Explorer
(To:TomU)
Excellent.  Thank you TomU.  I have to stick with M050 for now because our vendor is also on M050.  I did let them know they might need to go to M060 because of those issues.  Hopefully they will soon.
StephenW
(To:ptc-6101083)
If I was doing this, I would make a mapkey to select FILE, SAVE-AS, and then select the type that I wanted.
According to the documentation that Tom posted, .prt and 3 or 4 other creo file types will always be listed first, then you can order the other ones after those creo types.
