If it is PDF vector graphics, then a few programs can convert them into .dxf files, which can be read into a drawing. If it is a bitmap, you need to have an OLE server, such as Office 97 Access installed because PTC does not have internal software to show Bitmaps on drawings. PTC turns that job over to an OLE server - hence Insert Object. It is not inserting a bitmap into the on-screen image, just a link to a bitmap which is turned over to the OLE server to generate the on-screen image. You'll also have to use MS printer manager to get output as it is the only printer that is equipped to use OLE servers.
