"Could not locate sketch" error in VSS
David_M
I have a model, which is a new part that includes copied geometry (surfaces only). When I try to start a Variable Section Sweep in this model I get the error "Could not locate sketch: side.TIFF." which isnt' a file I'm familiar with. The error appears when I push the 'sketch' button within VSS after adding the trajectories, but I don't get the error if there is just one trajectory.
Does anyone know what might be going on?
BrianMartin
(To:David_M)
Weird!
If you create the VSS with a single trajectory, can you go back and add additional ones or does the error appear? This almost sounds like a bug-type error. Do you have a file we can look at... or a screen shot? I tried to search through the PTC Knowledgebase but PTC is down for scheduled maintainence.
Let's revisit this on Monday.
Take care...
-Brian
Patriot_1776
(To:David_M)
Perhaps the VSS was made with an external sketch instead of an internal one?
