"Most wanted" angled cut on sheetmetal wall
mmuhamedagic
Here is the wanted geometry (pic below):
And here is the extrude cut step:
Is it possible to get wanted geometry working inside sheetmetal aplication, or do I must use some other feature or aplication ?
I´ve worked this in Creo 2 parametric.
Thank you in advance
All you need to do is turn off the "Remove material normal to surface" button.
3 REPLIES 3
So obviously . Some time I just don't have time to read info message that automatically appear.
Thank you Andrew
... and if that solved the problem, don't forget to mark the answer as correct.
Thanks, Dale
