reduce bend length
vdevan
reduce bend length
hi,
i have to reduce the length of the bend, how ever the flange length shall remain the same...
in the attached image i have done by doing an extrude cut ..
is there an option in creo to do this ...
Thanks in advance...
You can create a "User Defined" flange, and sketch the reduced bend. No need for extra features.
3 REPLIES 3
BenLoosli
(To:vdevan)
Don't think so.
You may also do the flange width equal to the bens, then add a secondary flange to the first to get back the width. This method may cause less issues with unbending.
vdevan
(To:HamsterNL)
Thanks a lot my friend...
