reset to factory settings, where can i do it ? ptc creo mod ... version 6.0 privat
wpimiskern
hallo, i am Walter !
i am using ptc creo modelling Software Version 6.
i would like to get help for reset to the factory Settings. i worked with creo modelling express Software now for month. and had changed many Settings. so it is hard to do further work by this Settings. i did not find an menu or menupoint or somthing else, for reset this cad program. maybe ther is to do a command on the Input line. but this part of the cad program, i had not used until now. typically Windows Standard Programm have the possibility for reset to the factory Settings.
(i am better in german language, if somebody answers, who is german)
thanks a lot for an Precie answer.
4 REPLIES 4
StephenW
(To:wpimiskern)
Toby Metcalf
Toby, this is Creo/elements direct question.
Walter,
Toby will move this question to the Creo/Elements forum for you so you will get some help.
Welcome to PTC Community Walter Pimiskern‌ - I have moved your question to get the right eyes on it.
Thank you Stephen Williams‌ for the suggestion.
Best,
Toby
lfortner
(To:wpimiskern)
Remove %appdata%\PTC\Creo Elements Direct Modeling Express 6.0
and restart Modeling Express.
In the official version it is as follows:
File -> Settings -> UI...
Then Customizations -> Reset Settings...
