shape tolerance first zero before dot missing
Spedex
when I create a shape tolerance it looks like that:
But actually I want it to be 0.02 instead of .02.
Did not find a way to fix that.
Does somebody know?
Greetings
Spedex
StephenW
(To:Spedex)
There are drawing setup options you'll need to review
gtol_lead_trail_zeros
lead_trail_zeros
dim_tol_lead_trail_zeros
lead_trail_zeros_scope
StephenW
(To:Spedex)
lead_trail_zeros
Spedex
(To:StephenW)
Changed the second option (lead_trail_zero) to metric, worked.
Thank you.
tbraxton
(To:Spedex)
What drafting/drawing standard applies? That will govern the use of leading zero on drawings and MBD annotations? ISO vs ANSI drawing setup will affect how this is displayed.
You can override with config options as presented by @StephenW .
Involute Development, LLC
Consulting Engineers
BenLoosli
(To:Spedex)
Besides the options mentioned by Steve, your part dimensioning units will play into leading vs trailing zeros being displayed according to your chosen standards.
