show datum axes in drawing
rollinsn
Hi all,
Simple "where do I click?" question in WF5 coming from WF2...
Used to be in the "show dimensions" dialog. Now it is in Ribbon Heaven.
How do I show axes on a drawing?
Also
How do I create a broken dimension in a detail view? (the view shows one
leader and the other end of the dim is a double arrow...)
Thanks a lot,
-Nate
This email may contain material that is confidential, privileged and/or attorney work product for the sole use of the intended recipient. Any review, reliance or distribution by others or forwarding without express permission is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
1 REPLY 1
kkja
(To:rollinsn)
Select Annotate tab;
Show Model annotations;
Or
Right click on the view;
Or
Right click on the feature in the tree;
Once the Annotations window opens choose the tab on the far right for axis.
Jeff <><
