Hi friends,
How to reasign "start.asm" if have done assembly with wrong start.asm? please help me
its urgent
Thanks in advance
sharath
I think that there is no 1-step procedure. You have to modify your assembly manually to add all differences.
Martin Hanak
Martin Hanak
There is no easy way to replace start_asm after creation of component (out of the box it is impossible).
You can use Model Check to fit your requirements.
But, could you wtite more details about issue - what do you want to change?? maybe mapkeys will be useful.
regards,
gucio
With it being an assembly, how hard would it to be to just start over with the correct start.asm?
