superscript/subscript variable in note string (?)
TomD.inPDX
Creo 2.0 M040.
I'm having trouble formatting a note using a variable within the superscript/subscript delimiters.
If this a new bug or am I missing something here?
part relation: test=10
part annotation note: &test return "10"
part annotation note: test@+&test@# returns "test(superscript)&test"
I put in a support case but I know you guys and gals are probably faster with an answer.
Particularly interested if this fails in WF or Pro|E
Uhggg! SAD! Cannot be done ...according to CS.
James62
(To:TomD.inPDX)
How about using a symbol?
Does this value come from part relations?
Not sure about symbols. They should work fine.
The very basic example failed. Annotation in the part file using a part relation. I tried every angle, no go.
See this thread that got me thinking about it: tolerance limits addition issue I was trying to format the table data and couldn't. What you see is a complete work-around.
James62
(To:TomD.inPDX)
Ah, I see.
Nice solution there. That trick with overwritten model dims never gets old.
