How do I create a mapkey in creo 2 to switch to window number 1 or 2 or 3 and so on... whenever I try to make one it will only work for the part or assembly windows that were open when the mapkey was made
Here is an example of what I get
mapkey w1 ~ Command `ProCmdWinRadio` `133830-220.ASM.1`;
And I have tried editing it myself several different ways, below is at least one thing that I have tried
mapkey w1 ~ Command `ProCmdWinRadio` 1;
mapkey w2 ~ Command `ProCmdWinRadio` 2;
Anyone have any thoughts if this is possible
Adam
Message was edited by: Adam DeVries
Here is an example that works:
mapkey w2 @MAPKEY_LABELSwitch to Window 2;\
mapkey(continued) ~ Activate `main_dlg_w2` `main_dlg_w2`;\
mapkey(continued) ~ Command `ProCmdWinActivate@context_main_dlg_w2`;\
mapkey(continued) ~ Activate `main_dlg_cur` `main_dlg_cur`;
Josh
Josh
If you work with windows 7 you can easily switch windows by clicking on the taskbar and afterwards <ctrl>+a to make the windows actif.
Best regards,
Christophe
Hey Guys,
There is also an option under Tools>Customize that allows you to place a list of current windows on your menu bar; see below: (List of Current Windows)
Hey,
Is this also for creo2.0, because I don't find it for the moment.
Best regards,
Christophe
Hello Adam,
I found you thread and seems to do the trick for what I am trying to have: do you currently know whether it is possible to have this mapkey opening just the drop-down menu of the window icon? so that I can then type the number to select the model (this is because I usually don't know the number corrsponding to the model I want to open):
I already tried as you did to edit the mapkey leaving for example just the `ProCmdWinRadio`:
and also ti record with the mouse just the click on the icon , but with no success.
would be very comfortable...
thanks
bye
Tommaso
