.tbl to .xls
pedgar
.tbl to .xls
Hi everyone I have a beautifull table in a .drw, inside pro-e. As far as i know, if i want to save that table, i have 3 options: as tbl, as csv, as txt. The problem is the following: none of those table file formats is usefull in MS excel. If i open a csv or txt i´ll get a batch of letters and numbers and comas, but no table at all. So, is there any way to export a valid excel format from pro-e? Thank you so much!
u can save as .txt and open it in MS excel.
Edgar, You should be able to export yout table as a CSV format. Then, renove the index number from the file (file_name.csv.1 remove the "1") name in windows explorer. As soon as you fo that, the file icon should change to a familiar excel type. I do that all the time and have not had any problems. It exports beautifully to excel. Good luck.
