hello
i have a question refer at posibility to create a template with flatt pattern in sheetmetal
In this moment i have a template with front left and top views but i want to have flattpattern in sheetmetal template
tks in advance ![]()
Hi Redro,
I don't think what you are looking for is possible, as it will be necessary to add the flat pattern instance to the drawing, using Add Model, before you can show the flat pattern in the drawing view.
If you create a drawing using the flat pattern instance, then all the views on the drawing will be of the flat pattern.
Please let me know if this made sense or you would like me to clarify.
Amit
hi amit,
i want a "view" with flat pattern like isometric in one corner of drawing
this happened in a template
tks
