tolerance for overridden dim's
TracyWillis
Can someone tell me how to get Creo 2.0 to display a tolerance for an overridden dimension?
The system will let me place a tolerance in the drawing on a created dimension but if I have to (@o) override that value then the tolerance disappears from the drawing dimension. It's still shows in the properties box of that dimension but the tolerance doesn't display in the drawing.
Is there a detailing option that will allow tolerances for overridden dim's?
Second choice for a fix would be to manually enter the tolerance text.
If someone knows how I can enter that string so that non-symmetrical tolerances show up in the Over/Under format rather than +.001/-.004.
I'd like the +.001 to be on top and the minus value directly under it?
Any help will be greatly appreciated.
Thanks to all
tw
Placing this line right after the overridden value worked.
@++.0010@#@--.0040@#
[cid:image001.png@01CE6B69.B74825E0]
The @# at the end resets the text to fall on the same line as the @d line or (@o in my case)
Also - should point out that without the @# in the middle the system will ignore the @- and place everything on the superscript line.
Had many replies with this same solution so thank you to everyone.
Good day all.
tw
