in drawing there are many ways for displaying tolerances in drawing , i want to display tolerances to be like tol1.jpg not like tol2.jpg or tol3.jpg
all pic were attached
Yes, it is an old drawing option available in Creo 2.0 as well. Make sure your are checking this in drawing options not in config options (File > Prepare > Drawing Properties > Detail options > Change)
Just curious as to why you didn't just attach the jpeg images directly instead of putting them in a .rar file. I generally don't open .rar files unless I am absolutely certain I know the contents.
when i tried to put the image directly the massage ( this image type is forbidden ) why i do not know
Compressed file formats are blocked by corporate firewalls. I can not open .zip or .rar files.
i tried all the images extensions but no new ![]()
All,
tol1.jpg from Demac was as:
I don't think directly you can get this, however as an alternate option you can try using Plus-Minus tolerance mode and set lower tolerance to 0.0. After that blank 0.0 (lower tolerance) using drawing option blank_zero_tolerance as yes.
Result will be as:
thanks for reply but i did not find blank_zero_tolerance in drawing options ( i'm using creo 2)
I'm in Creo 2 also. It's there under the tolerances section in the drawing setup. (not config.pro)
FILE, PREPARE, DRAWING PROPERTIES, change (across from detail options)
that is what i want thanks
