Unable to load the custom drawing format (.frm) in proe session
the error says :
'format' does not exist in the database..
whrere format.frm is the drwaing format
please let me know how i can load the format
Hi
I would request you to check one thing
The version in which the format is created and the version in which you are working
For example-If you are working in WF5 and format is created in creo then this type of message will appear
Try to just open the format and check
(this might be one reason)
Regards
K.Mahanta
I have already checked it. The version is same. Do you need to register the format somewhere in proe configuration ??
Regards
Awadhesh
Hi
There is no such register option available in pro-e
When you open any exhisting drawing it searches for the format in
1- Working directory
2- Pro format directory
You can set your pro format directory in config.pro option pro_format_dir
Can you give a screenshot of your error message?
Regards
K.Mahanta
