variable text in patterns
colin
2-Explorer
That worked, thanks Wayne.
---- Wayne Nivens <-> wrote:
> Chris,
> Got this off the exploder several years ago so it's a bit dated but should still work.
> 1) In your text sketch, sketch a point dimensioned X units away from zero.
> 2) Create a sketcher relationship, LABEL=itos(sd0/X) (or whatever the sd# of the X dimension
> was). The ITOS function is "integer to string" and the equation sets the text at X units="1",
> X*2 units="2", etc.
> 3) Create your sketched text and choose LABEL as the driving parameter. sketch your text
> relative to the sketch point you just created, that way the text label and the point will
> move together. The simplest would be to draw the text line straight up from the point and
> then set the text to be centered horizontally.
> 4) Finish the sketch. Modify the X dimension and watch the fun (if you did it correctly, the
> number will rapidly change as it dynamically moves the location)
> 5) Create a dimension pattern picking the X and incrementing by X.
jlippeth
(To:colin)
Users,
How would I go about a text pattern in two directions, X and Y
For example a 4x8 configuration starting with 401 in upper left corner @x6” and y10” with an x and y pitch of 3”
401 409 417 425
402 410 418 426
403 411 419 427
404 412 420 428
405 413 421 429
406 414 422 430
407 415 423 431
408 416 424 432
Jscott
