I have had this problem over and over. In a drawing I insert a general view and the view selection box will be so large that it ends up overlapping other projected views. This makes it very difficult to select the correct view that you actually want to move. The size of the block is small but the imported data that I used to build the block is very large. I hide the import feature but the selection box continues to be as large as the imported feature. Does the selection box have to be that big? is there a setting where I can chage the size of the selection box? I have attached an image showing the issue.
Creo elements / PRO 5.0
Build M120
In Reply to
