weight of assy in simplified representation
thlavinka
7-Bedrock
Is there some way to show (in drawing) the total assy weight without parts excluding the simplified representation?
Thanks for help in advance.
T.
bduncan
(To:thlavinka)
8 REPLIES 8
hi,
you have to sum mass in repeat region.
Please look at the sample.
regards,
gucio
Krzysztof
thlavinka
7-Bedrock
(To:Gucio)
Thanks Krzysztof !
BTW: isnt there some posibility to have the information in frm file (similar to "&pro_mp_mass)?
this value in red square represents the total weight (including parts that are actually not a part of the fixture...)
B.R.
T.
It i spossible.
In frm file you have to add repeat region with right sum.
Krzysztof
thlavinka
7-Bedrock
(To:Gucio)
I am sorry - cannot get the &total_mass working 😞
Total Mass is parameter that was added by me.
All you have to do is:
1- create frm file;
2 - create table with repeat region;
3- add default parameter &asm_mbr_mass - unless you have your own paramater that calculate mass
4 - Table > Repeat Region > Summaration select repeat region, then Add > By Name > ASM_MBR_MASS, type name of parameter (in my sample TOTAL_MASS), accept, and select cell where parameter should be placed.
good luck
Krzysztof
bduncan
(To:thlavinka)
I will make a short video for you.
Thanks a lot..
bduncan
(To:thlavinka)
