what is internal geometry error?
jt-3
what is internal geometry error? and how to bypass it? trying to unite parts.
1 REPLY 1
FriedhelmK
(To:jt-3)
Hi, can you specify a little bit more
Whitch program and version do you use?
You are here in the Creo Elements/Direct forum.also referred as "Direct Modeling"
Helpfull should be the upload of the file with the problem.
Best regards
Friedhelm
(Please write info in your Signature) Sysinfo: I use Creo Elements Direct Drafting, Modeling and Express 6-8-9 ( formerly CoCreate- SolidDesigner and Drafting or ME10 )
