why are blue lines showing on mirrored part
Amcare
I mirrored a part and the mirrored part is showing blue lines, I'm not why or how to get rid of them.
1 ACCEPTED SOLUTION
DavorGranic
(To:Amcare)
You can just hide mirror feature it will hide all but solid.
14 REPLIES 14
please attach a picture of mirrored model.
MH
Martin Hanák
Amcare
(To:MartinHanak)
blue lines.PNG Here it is. These lines are showing up whenever I mirror copy any parts.
Thanks, for your help in advanced.
Kevin
(To:Amcare)
Looks like sketch features that were used to create the original part. You might try ruled layers to see if you can get those on them and hide the layers.
Amcare
(To:Kevin)
Yes, I believe they are, but wasn't sure how to keep them from showing. I will try your suggestion though. thanks.
Amcare
(To:Amcare)
No such luck. I click on the layers, and the layers properties is greyed out.
I hope you can create test part and upload it using How to Attach a File to a Discussion Reply procedure. Community will be able to download file and investigate its behavior.
MH
Martin Hanák
Amcare
(To:MartinHanak)
Here is the files. I included the mirrored part and the original part. I hope this helps.
Current situation ... curves are visible
Solution 1 ... hide Merge feature
Solution 2 ... edit layer definition, set Curve filter and select individual curves, then hide layer
MH
Martin Hanák
Amcare
(To:MartinHanak)
I just hid the mirrored part feature and it removed them.
Kevin
(To:Amcare)
Try the following rule. This selected the curves for an external sketch for me.
dschenken
(To:Amcare)
Layer properties only work if a layer is selected. I don't recall 'properties' applying to 'layers'
Perhaps you need to create at least one layer and select it.
DavorGranic
(To:Amcare)
Amcare
(To:DavorGranic)
Thanks, I will try that.
Amcare
(To:DavorGranic)
Thanks, it worked like a charm.
