Why are my axis icon's grayed out? I want to show axis lines in the model/assembly but the icon appears to be inactive or grayed out.
Steven,
maybe axis display is disabled in config.sup file.
Martin Hanak
Thanks for the reply. Funny thing is that the version that they are greyed out on are m160. All the other users are using m080. All the users pull from a common config.sup file. Did investigate that first.
Steven,
If I am not wrong, it was changed from Creo 2.0 M090 or M100.
Mahesh, could you expand on your answer?
Thanks.
Steven,
This is in continuation of replay from Martin Hanak.
Starting from Creo 2.0 M100 there was change in functionality. If display option for axes, csys etc are off in config.sup (e.g. display_axes as no in config.sup), icons to enable or disable will remain inactive. Check earlier post at
Re: Axis Display and Csys display on Creo 2.0 M100 is grayed out !
You can add some more details if this is not as per your query.
Steven,
Does the from in post answer your question?
