why on creo 3.0 the button guide ( up and right ) opens the guide of creo 4.0 ?
mamobono
6-Contributor
why on creo 3.0 the button guide ( up and right )opens the guide of creo 4.0 ?
see the pdf attacked
TY
Info from CS253942 ...
MH
Martin Hanák
9 REPLIES 9
TomU
(To:mamobono)
It's a known issue.  PTC will have to either fix it on their webserver or fix it in a future build of Creo 3.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS254679
llie
(To:mamobono)
All,
This is fixed in Creo 3 M120
TomU
(To:llie)
Are you sure?.  We are running M120 and the help button still takes us to the Creo 4.0 online help.
llie
(To:TomU)
Tom,
My mistake. We have our config.pro pointing to Creo 3.0 help located on a server.
mamobono
6-Contributor
(To:llie)
thanks for the answers
you can download and install Help on local disk to avoid this problem.
MH
Martin Hanák
MH
Martin Hanák
mamobono
6-Contributor
(To:MartinHanak)
it works
great
ty Martin
A work around is not the answer here!!!!
If there is a work around, it should be for Creo 4, not 3.  PTC should put the Creo 3 documentation back into the correct area (http://help.ptc.com/creo_hc/creo30_pma_hc/usascii/index.html) and create a new site for the Creo 4 documentation.  The address even has creo30 in the path!!!!!!!!!!
I shouldn't have to patch my installation because someone at PTC put the documentation for Creo 4 in the wrong spot.
