in Creo 4.0 (M040) the window size between model (blue) and drawing (black) mode window have a different size (See picture).
from Creo 2.0 I have set
windows_scale 1
menu_manager_position adaptive
thermo_position_hint no_window_overlap
attach_menumanager yes
I would like to have the same size for all windows and some space to the right for the menu manager. Something must have changed from Creo 2.0 to 4.0?
Regards
Jan
I can't reproduce your problem using my CR4 M040 installation. Start investigation without your config.pro.
Thank's for the reply. I started with an almost empty config.pro - but no change. I noticed the difference of the graphic window size between model and drawing mode only arise in a so called linked session of Creo and PDMLink. In stand alone Creo I don't see this behavior.
Jan
Try setting the config.pro option
reserved_menu_space
Thanks for the reply. I tried reserved_menu_space 1.6 and both windows, drawing and model window, have shifted accordingly with the offset between them.
Regards
Jan
