Hi all,
I am having an issue with one of our drawing templates at work. The template consists of a bitmap image object and when I try to place any views on a drawing using the template they show up behind. If I pan the view or print a pdf it shows up but I cannot see anything on the drawing otherwise. I had a coworker open up the drawing and he does not have this issue.
Does anyone know of a drawing/config setting that would fix this issue?
