Use Preset Explode if source data is definied in the subassemlies and not only in the top-level
MS_10560564
2-Explorer
Expect to obtain the Creo Elements / Direct Modeling configurations of the subassemblies in the Preset Explode  of Creo View
Description:
In the help you can read that "You can use the Preset Explode function only if the source data has top-level explode states defined".
This is the structure on Creo Elements / Direct Modeling.
The objects are stored in Windchill.
The visualization of Sub-Assy1 is a monlith visualization  and the visualization of the Top-Level-Assembly /Tops-Assy is a strutcure visualization.
Only the Modeling configruation  off the Top-Level-Assembly is available in Creo View in the
Preset Explode
 We also expect to obtain the modeling configurations of the subassemblies in the Preset Explode  of Creo View
llie
(To:MS_10560564)
You can only obtain that type of functionality if you are using Creo View Positioning Assemblies. Otherwise it just does top level assembly explodes.
