How do you apply rotational constraints when doing the structural simulation in Creo? I'm using rack and pinion from power steering system for the simulation.
Use a pin constraint. The 3rd entry is an optional rotation constraint. Use two planes to define the angle. These planes must be parallel to the pin axes.
Thank you for the answer, but it's a little confusing. Do you mind explaining step by step in detail.
Sorry for the trouble.
I may have misread your question. I was thinking constraining the parts in an assembly, not providing rotational stress for analysis.
I only have the simulate light version, and I do not see rotational loads as an option.
There's a couple different ways you can do this:
What method you use depends entirely your simulate goals, the physics you're trying to model, the geometry of the problem, etc.
