Stress result pin constraint
Hi All,
I'm using PTC Creo 8.0 with simulate basic extension.
I'm running into a very simple problem but can't find the right solution yet.
To visualize the issue I made a simple strip with holes on both ends.
In one hole I created a bearing load in the length direction of the strip.
In the other hole a pin contraint.
I my world this should give the same stress results in both holes. After all: "For every action in nature there is an equal and opposite reaction". But as shown in the screenshot below it isn't the same at all..
I've already been testing with different solutions, but none of them resulted in equal results.
Most close so far was to divide the hole in different regions and connect the upper region with a point in the center with a rigid link. However this means a lot of trial and error with the size of the region which is not very practical and very time consuming
Somebody here knows what the right solution is?
Thanks in advance!
