Bad Error
fstopelli-2
Bad Error
Hello!
Sometime This happened to someone?
It's no clear about the problem of the 3D element..
Good Life
Hello Federico,
This error can be occurred, sometimes if Shell Geometry is used
You could try following steps to solve this error:
  • Set AutoGEM Type to Midsurface
  • Check Ignore unpaired surfaces option in AutoGEM setting
  • Try to create mesh again
Jignesh
fstopelli-2
(To:jmoradiya)
Hello!
thank you but the command is unable
