The new right click menu is nice and big. It would be better if I could eliminate all the stuff I don't use.
I suppose the next best solution would be mapkeys for any common function but I still prefer the good old right click functionality.
File > Options > Shortcut Menu to customize it.
On a related topic, Toolkit users wishing to put their TK commands into the shortcut/rmb/popup should take a look at
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS246321
for a description of how it changes from Creo 2 to Creo 3.
Thanks Matthew,
That's a whole lot more options than I was expecting.
Vince
Yeah, the whole idea of a separately-configurable rmb menu per ribbon tab is pretty powerful.
