How do I highlight part of a surface with an annotation feature?
Hi
I want to place an annotation feature on a part and when you click it part of a surface should be highlighted.
This is possible if I split the surface first but as the entire surface is coherent I can't use the split surface function as it doesn't support to split with a sketch.
Is there a way to highlight part of a surface or create a split surface using sketches?
Can it be solved in another way?
Best regards
Zacharias
