Is there a way in Creo Simulate to use a surface to create shell elements? This is not a midsurface shell compression. I created a simple "L" solid part with a surface extrusion. I thought the autoGEM control "hard surface" would achieve what I wanted. But it doesn't. Is there a different setting that will accomplish this? I've attached photos of the part and the part meshed.
I discovered how to do it. Please see the attached video.
