Creo Elements Direct Customizations
mwick
7-Bedrock
I am having difficulty with having Creo Elements Direct 18.1 reading my AM_CUSTOMIZE file. I am getting the same response no matter what I try.
LISP error: The function AM..... (no matter what function I am trying to load) is undefined.
What am I missing? Is it syntax in the file? Do I need to define something ahead of time?
I am new to Creo and this file is a copy of the one that has been used for years. It works in 15.50 but we are upgrading to 18.1 so I am guessing there has been changes, but I need help "upgrading" this file.
Please help
Thanks in Advance,
Mike
5 REPLIES 5
GaryLinscheid
(To:mwick)
You should now set these preferences in the default settings interface.1.jpg
But wouldn't I have to do that at each individual machine? I would like to serve out these settings to all users and be able to make 1 change and have them all see it. Similar to how we do it with our Parametric install.
I have read through the customization help documentation and it is possible, but I must be missing something. I just don't know what.
Mike
GaryLinscheid
(To:mwick)
I have all our "global" settings located on a network share that is read only to users. Each user has a personal network share location where any of their personal settings are located.
A batch file is used to start Elements/Direct and pointers are set to load these settings. With this setup you only make a change in one place and all users are updated.
Batch file looks similar to this.
set SDSITECUSTOMIZEDIR="global location"
set SDUSERCUSTOMIZEDIR="user location"
"C:\Program Files\PTC\Creo Elements\Direct Modeling 18.1\SD.exe" -e SDLANG=english "C:\Program Files\PTC\Creo Elements\Direct Modeling 18.1\binx64\SolidDesigner.exe"
I have a system variable that defines the Corp Customization location, and it is reading that location on startup, it is just not reading the AM_CUSTOMIZE file in the ANNOTATION directory properly.
GaryLinscheid
(To:mwick)
I believe the commands that are giving you issues and no longer valid and should be set with the newer setting screen.
You can look in the help under documentation for advanced users and select the Intergration Kit link. There you will find a link to command syntax changes.
