Creo Flow analysis results for specific time step
DH_10857799
2-Explorer
Hi everyone,
is it possible to display for example the streamlines for a specific time step after I already ran the simulation? For example I simulated for 1 second and I want to see how the streamlines behaved at 0.5 seconds. Is this somehow possible?
I'm using Creo 4.0
Best regards,
Dominik
Thank you for your question.
I encourage you to bring more details and context to your initial inquiry. This will make it easier for you to receive meaningful help from other Community members.
Andra
cfdgeek
(To:achirila)
e.g. you setup is 500 steps for 1 sec, you can change saving to 250, you got 2 sres files one is for 0.5 sec, and the other is 1.0 sec. You can load it back and do post processing at that time step.
cfdgeek
(To:DH_10857799)
Hi Dominik,
You need to control the result saving frequency in the common model. After you simulate 1 sec, 0.5 sec result can be loaded back to do any post processing tasks.
