I want to analyze a bolt with preload to find the equivalent plastic strain. but when I given the preload and then trying to give the nonlinear analysis system saying as below image.
How to do the nonlinear bolt analysis with preload?
The following materials may be helpful to you:
I followed the same for defining Preload. even after that while giving analysis settings when i opt for nonlinear analysis it is showing the error mentioned.
