Flow Analysis Domain Icon Colors (Creo 7.0.9.0)
Hi. What do the different domain icon colors mean? I've noticed after meshing they can change from the bluish color they normally are. I know I've at least seen green (pictured here) and gray. For the model I'm currently working on, the green icon domains do not let me view any properties (e.g., temperature). Thanks. It would be really nice if there was a place to look up all this stuff that's not explained in help.
tmoserAnswer
I think it means that Creo Flow didn't creat any mesh for that domain. You may need to update that domains or even recreate it.
tmoser12-AmethystAnswer
I see. Looking at my streamlines that does seem to be the case. Thanks so much!
Hi please check the additional domains group in the simulation tree. Some models have some modeling issues, which may lead to gaps and issues when we get the tessellation from the geometry. Those can cause your simulation volume gets the wrong name and will be grouped in the additional domain group. You can still find those back and setup material property manually and then continue working on your simulation.
