Excel Analysis
BC_10219589
Excel Analysis
Hello All,
Has anybody had problems when using Excel Analysis and linking feature dimensions to an excel file values? It works at first but later the program creates a temporary file (a copy of the original excel file) and stops updating the values...
Let mw know,
Thank you,
tbraxton
22-Sapphire I
(To:BC_10219589)
Refer to this previous thread. It explains how the Excel file is managed.
https://community.ptc.com/t5/3D-Part-Assembly-Design/Excel-Analysis-loses-Excel-spreadsheets-and-create-new-one/m-p/736913
Involute Development, LLC
Consulting Engineers
First of all, thank you for your help.
I have a question regarding the thread you sent:
1. If I don't chanage the location nor the name of the file, why does creo create a temproary excel file? shouldn't it be always looking in the same path / name as default (and therefore find the original file I told the program to link the values to?)
Thank you
tbraxton
22-Sapphire I
(To:BC_10219589)
I do not know why the temporary files are generated. I would suggest opening a call with PTC support to get details on that.
VladimirN
(To:tbraxton)
angupta
(To:BC_10219589)
  go thru the support (About the Excel Analysis Output File). I am sure it will answer your query:
https://support.ptc.com/help/creo/creo_pma/usascii/index.html#page/model_analysis%2Fbemod%2FAbout_Excel_Analysis_Feature_Output_File.html%23
