Export Graph into CSV or Excel File or Read result files via another tool (multiple output steps)
JW_4259374
Dear Community
I am using Creo 8.0.8.0.
I would like to export or extract simulation results in a easy way into a csv-file or other file format that can be imported into excel.
Currently I am facing following problem. I have done a Contact Analysis using 2 time step and I also wrote.
In the post processing I created a graph using a measure (force) vs. time. Somehow I cannot export the graph. Also I cannot plot two measures (e.g. bolt force vs. input force) that shows their correlation over each time step.
Somehow Creo creates several output-files and also folder of each time step but I am not able to find how to use this file and to extract the information I am interested in.
Below you find a screenshot of the graph I would like to export into a CSV or other format.
Within the post processing tool (Simulate Result) I was not able to export a CSV file. It was only possible to create a "rwd" file.
Following I did:
- Nonlinear (Contacts) simulation
- Output: 6 Master Steps (of each of them "Full results" have been written out
Is there a way to read some of the output files to get the information I need e.g. res-file?
Does the res-file includes the measures of each time step?
Thank you for your support.
Somehow I cannot upload the screenshot.
skunks
(To:JW_4259374)
6 REPLIES 6
skunks
(To:JW_4259374)
JW_4259374
(To:skunks)
Hi skunks
Thank you a lot for the solution. Somehow the xlsx is not created but the grt-file which already helps me a lot.
Thank you!!
rrabe
(To:JW_4259374)
I found this topic due a point that you described - I also could not export the result as excel file (as I am doing since I started with this PTC product) - but had no problem to export it as .grt.
Copying the values from .grt to excel cause some formatting problems (it is not recognized as a number) what is easy to solve but causes unnecessary more steps.
As I wrote, I am using "save as excel" for the graphs at long time but now there is nothing stored in the working directory -and I am using Creo 10.0.4.0
This is not normal - we should be able to generate - and store - .xlsx files in the working directory, but it is not happing.
First I thought that was a configuration problem with my Creo - but now I see other people describing the same issue!
rrabe
(To:JW_4259374)
about the results not being exported as excel file, this seems to be a know issue and related to MS office security configuration.
For more details see  Article - CS413767 - Exporting result to an Excel file from the Graph (Chart-Tool) feature is not working in Creo Parametric.
_ This is affecting all Creo versions since 7.0
The official solution is:
_ "Temporarily disable any security labels or sensitivity labels applied to MS documents on the affected user's computer" - what in may case is a no go and not allowed.
_ Export the graph as tabular file format (.grt)
As it seems, until now exporting the graph as .grt file is the unique solution - although I dislike this formats since my excel has problem to right interpret numbers from this file having points or coma. A lot of manual correction is necessary.
Do not expect to have a good solution soon... If you use security labels or sensitivity labels applied to MS documents, this Creo function is gone...
rrabe
(To:skunks)
Hi Skunks
Can you please confirm that you are able to save - and find - the plot exported as excel file?
Like JW_4259374, I cannot find the resulting excel file in the working directory.
I never had this problem before and I am using this export function since ever!
So far the problem appeared in Creo 8 and 10. No idea when this started and if is user specific -  I mean, related to a specific configuration that was changed and the user is not aware.
Thanks!
skunks
(To:rrabe)
it worked with Creo Simulate Elite 12 🤔
