How to apply spring element?
JS_9824412
Kind of new to the Spring element in CREO Simulate. Is it possible to simply the 5 spring disc washers (see below illustration) with only one spring element? I have simply the rod as a series of beam elements.
Thanks for any hints.
Chris3
(To:JS_9824412)
If you make the spring an advanced spring then you can enter in the spring matrix in any of the vector elements that you need.
A beam does the same thing only it uses the geometry and material properties that you have provided to generate those stiffness values.
7 REPLIES 7
@VladimirPalffy Could you please take a look?
Chris3
(To:JS_9824412)
You can add datum points along the rod's axis and then connect beams or springs to those datum points to give you the stiffness / spring properties that you are looking for.
JS_9824412
(To:Chris3)
Thanks.
One end of the spring element will be attached to one of the datum points that you have mentioned, the other end will be attached to a datum point added to the fixed supporting plate at the center of its through hole. This datum point is part of the plate through a rigid link or RBE2.
I am implementing the above now.
Still don't know how to assign the stiffness values for compression spring. So I temporarily used a hollow beam to connect the two points for representing the stack of spring washers. I am not sure yet how much errors it has caused.
Chris3
(To:JS_9824412)
JS_9824412
(To:Chris3)
Thanks for your enlightening and encouraging feedback. I am motivated to make the change now: replace the hollow beam element with an advanced spring element.
Applied Kxx (the axial direction) as the calculated lb/in value, and let Kyy and Kzz be zero, the modal analysis shows rigid move modes. So gave Kyy and Kzz a random number saying 1000 lb/in as countermeasure. No idea how much error would be induced in vib analysis.
