I tried this way allready.i checked the repeat region
Model/rep also I am using Wild fire 4.0 with RSD 8.0 THe RESULT COMES LIKE THIS, It simply listing out all part numbers on repeated manner (its not giving qty & part number) the parameters i used are the same which u sent &asm.mbr.connprm.pin.signal.seal_name &rpt.qty
I´ll try it in another assy and ill let u know the result again.
