Hi everyone,
Is it possible to refer any parameters which defined in Tools => Parameters, when I create user defined measures in Mechanism ( Analysis => Measures)?
I have a sheave in the assembly and the diameter of the sheave is defined by a parameter. And I want to define a variable in the Mechanism which is related to the diameter parameter. But I don't know how to refer the parameter in the variable expression. I don't fine a way to define a variable to represent the diameter size in Mechanism Measures neither.
Could you give me help?
ZR
I find the solution. the parameters can be added by "insert constant from list".
ZR
ZR
