Hello everyone
I am not good at English, so I'm sorry if it was a funny translation.
I asked a question on how to check the gear mechanism with MDO and it was able to run.
However, since MDO can not confirm the stress analysis (contact analysis?) Of the gear, I think that we will check the stress of the gear with Simulate by diverting MDO data, but since it is not detailed in the analysis, the definition method is well understood not.
I will attach a reference file.
Could you tell me the definition method to check the force generated during gear drive?
Thank you.
Thanks for the advice.
About the reaction force of the gear, it is helpful to have a sample using simulate and a reference example if you have it.
Thank you for attaching the sample data.
I would like to verify by referring to the received data.
Thank you very much.
