Is string_length() still a valid relation function?
dschenken
I looked for this in the old help and in the help at http://help.ptc.com/creo_hc/creo30_pma_hc/usascii/index.html#page/pma/introduction/about_PTC_creo_help.html Neither place mentions string_length(). But at http://www.mcadcentral.com/creo-drawing/14098-string-functi-ns-proe-relati-ns.html one responder has string_length in a list extracted from some version of Help file.
As in the title - is string_length() still a valid relation function? Looking for WF5, Creo, Creo 2, and Creo 3 validation.
TomU
(To:TomD.inPDX)
To get to the page with the information on it, I manually navigated down to where I knew it was.
Pick the question mark in the corner:
This takes me to the help center (on PTC's website)
http://help.ptc.com/creo_hc/creo30_pma_hc/usascii/home.html
From there drill down to the topic:
10 REPLIES 10
It is in the list of functions, yes.
TomU
(To:dschenken)
Yes, still there. From Creo 3.0 F000 Help:
TomU
(To:TomU)
Of course the newfangled help isn't smart enough to find it.
TomD.inPDX
(To:TomU)
Help needs help! Anyone figure out why the new help files are only half the size of the previous versions?
TomD.inPDX
(To:TomU)
How did you get to that page, Tom?
TomU
(To:TomD.inPDX)
dschenken
(To:TomU)
Thanks Tom,
Not only isn't it where it should be, in the string functions section, and help doesn't find it, it's in an application section that's just wrong - where are the arguments being passed -to-? There isn't any argument passing in relations. It's all one big piece with only global variables and no user defined functions. String_length -used- to be in the string functions section, based on the previous link, so someone took the trouble to break it on purpose.
Dale_Rosema
(To:TomU)
Is that because it is a Creo Parametric Help Center and not Creo?
TomU
(To:Dale_Rosema)
Initially I just had Creo 3 installed, but not the help center. After installing the help center locally (and then using it), the search actually works correctly:
As far as what section, it's the same in WF5 (CEP/5):
TomD.inPDX
(To:TomU)
Lipstick on a pig comes to mind here
