Is there anyway to get this function back?
SYNDAKIT
the underlined letters in the selection options was a real time saver. Does anyone know how to get these back?
in CR3, PTC implemented new functionality which enables user to configure context menus.
See https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS180863
Probable side efect of this new functionality is removing underlined letters in context menus (this is my opinion, only).
MH
Martin Hanák
10 REPLIES 10
  • click right mouse button
  • press ALT key
MH
Martin Hanák
SYNDAKIT
(To:MartinHanak)
I can't get that to work in drawings. sorry I should have been more specific.
for some reason it still shows up in places like the tool bar and the navigation tab, but not in the drawing window
You can see the menu displayed on your picture only in case that mouse cursor is located on Ribbon.
MH
Martin Hanák
SYNDAKIT
(To:MartinHanak)
If I understand you; yes, that's my fault. I needed to get a picture to show the underline. I will modify it
SYNDAKIT
(To:MartinHanak)
Here it is but with Creo 2
SYNDAKIT
(To:SYNDAKIT)
this is a better picture. in previous versions of creo some of the commands would have an underlined letter that you could just tap and it would choose it.
in CR2 M070 when I select a table and press right mouse button, I can see the following menu - some commands contain underlined letter, others not. It looks like this is current Creo behaviour.
MH
Martin Hanák
SYNDAKIT
(To:MartinHanak)
it seems that it didn't get carried over to creo 3
but could I add it somehow?
MH
Martin Hanák
SYNDAKIT
(To:MartinHanak)
yeah it sure seems that way.
Hey Martin I appreciate your help on all this. You are always a big help with all my questions!
Thank you!
