Isolate selected components in assembly
I am a beginner in creo. In previous cad software which i used (inventor and solidworks), I can easily isolate the components in assy environment, but in creo I cant find a proper way to do it. I search around the web, which I find a poor way which is: select the components you want to isolate --> representation--> master. But this method cant longer be used once you are in another simp representation mode. So please advice the fastest way or at least the efficient way to perform the 'isolate' function since me and my colleague use "isolate" function quite frequent when need to modify part feature in assembly environment.
