Version: Creo Parametric 10.0.4.0
I am trying to use the updated Manikin models. When I try to move the manikin model Creo requires that I have access to some of the sub-models. This makes using the manikin models more challenging. I can move the manikin model around, but if I try to edit a joint, then manikin requires access to the lower level assemblies. If all the models are read only, I can't continue. The manikin model should need to write access to these lower level assemblies.
Some of the lower level assemblies contain "packaged" components. I understand this is not best practice, but probably should stop me from moving the manikin arm. Will probably submit a ticket to report the fault.
