do you know how i can define the material definition in CREO (tensile Strenght) ?
thanks
probably better exponential plasticity law...
thank you very much for your answer... i tried to modify the material as you indicated but i still can't submit my part with the maximum load (breaking load of the part) that i need... do you thing i forgot to clearly define my material (Attached)?
Hm... The material law 'looks correct
Can you please take a look at my construktion (attached) ? i've been trying to simulate this for more than two months to no avail... (tensile strenght= 1000MPA, yield strength = 640 Mpa)
thanks a lot...
